#206781 - 25/02/2004 10:19 Hiding "Plays: 0"
I know I had this set on my empeg prior to my recent involentary purge, but I can't seem to find the setting that did it.
Thanks.
#206782 - 25/02/2004 10:33 Re: Hiding "Plays: 0" [Re: Phoenix42]
robricc
I think it's in emplode under File -> Properties somewhere.
#206783 - 25/02/2004 11:24 Re: Hiding "Plays: 0" [Re: robricc]
"Configure Player" if I recall correctly. Note that the setting is only valid in 2.0 final. 3.0 alpha doesn't have the disable feature, it was added after the code split.
#206784 - 25/02/2004 14:52 Re: Hiding "Plays: 0" [Re: tfabris]
I must be blind, I can't see the option.
However I though it was done through Hijack - I don't know why I think this, but I don't see any mention of that at Mark's site or in the FAQ.
#206785 - 25/02/2004 15:16 Re: Hiding "Plays: 0" [Re: Phoenix42]
Connect with emplode. File, Configure Player, Advanced. It's one of the check boxes.
If the option isn't visible, check to make sure that both your player firmware and emplode are at exactly version 2.0 final.
#206786 - 25/02/2004 15:31 Re: Hiding "Plays: 0" [Re: tfabris]
Ah, that might be it Tony, I've got beta2.13 with the latest Hijack.
Anyways this is what I see.
Maybe I need to lay off the coffee!
#206787 - 25/02/2004 15:34 Re: Hiding "Plays: 0" [Re: Phoenix42]
Well, as Tony mentioned, that option isn't available in 2.0 betas or in v3.0 alphas.
But if you'll wait a few days, I think I'll have something that will take care of this problem for you.
#206788 - 25/02/2004 20:29 Re: Hiding "Plays: 0" [Re: tonyc]
Hmmmm.........Thanks Tony and Tony.
#206789 - 25/02/2004 20:51 Re: Hiding "Plays: 0" [Re: Phoenix42]
oliver
i'd just upgrade from 2.0 beta 13 to the Final Release of 2.0
#206790 - 26/02/2004 02:25 Re: Hiding "Plays: 0" [Re: Phoenix42]
I did it on mine using UltraEdit on the en_UK.msgso file as described here
Didn't know there was actually a setting with a button in some versions.
#206791 - 26/02/2004 07:18 Re: Hiding "Plays: 0" [Re: oliver]
/me heads off to find some ketchup so that my foot tastes better
